Date/Time: Fri, 22 Nov 2024 13:39:53 +0000
Sierra Crash - any idea what is causing it?
View Count: 1787
[2013-05-15 15:33:32] |
infpz - Posts: 826 |
Problem signature: Problem Event Name: APPCRASH Application Name: SierraChart.exe Application Version: 700.0.0.0 Application Timestamp: 51926155 Fault Module Name: OLEAUT32.dll Fault Module Version: 6.1.7601.17676 Fault Module Timestamp: 4e58702a Exception Code: c0000005 Exception Offset: 00003e8d OS Version: 6.1.7601.2.1.0.768.3 Locale ID: 1033 Additional Information 1: 0a9e Additional Information 2: 0a9e372d3b4ad19135b953a78882e789 Additional Information 3: 0a9e Additional Information 4: 0a9e372d3b4ad19135b953a78882e789 |
[2013-05-15 15:41:40] |
Please refer to help topic 17 here: http://www.sierrachart.com/index.php?l=doc/helpdetails17.html If you are using the Spreadsheet Study and outputting data to Excel, then avoid using Excel. We do not support any technical problems that are encountered when using Microsoft Excel. This can also be caused by the TransAct interface software and that problem will be resolved next week with a new different interface being used to TransAct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-15 15:42:08
