Date/Time: Sun, 29 Dec 2024 06:34:56 +0000
Volume by Price Alert
View Count: 954
[2014-10-31 15:41:14] |
User765038 - Posts: 22 |
SC, In using the VbP (Volume by Price) study, what is the formula I should use to activate an alert when the current price action touches the POC (point of control) from either direction (above or below)? Thanks and regards, Rod |
[2014-11-06 18:00:43] |
For this you will need to use the Volume Value Area Lines study. It is not entirely reliable accessing the point of control data from the Volume by Price study. You will need to use a Simple Alert formula like this with the study: =AND(H>=sg1, L<=sg1) Here is the documentation: https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-26 22:30:56] |
SC Support, If top band (VAH) is SG2 and bottom band (VAL) is SG3, what is the formula that triggers an alert when price action crosses either line? Thanks and regards, Rod |
[2016-01-27 04:32:12] |
You can use this Simple Alert Formula: OR (CROSSOVER (SG2, H), CROSSOVER( SG3, L)) Here is the documentation: https://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php#EnterAlertOnStudy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
