Date/Time: Sun, 19 Jan 2025 19:36:32 +0000
Renko Bar predictor study - Flex renko
View Count: 3464
[2014-10-31 01:33:03]
N!co - Posts: 140
Could you please make the Renko Bar predictor study to show the correct values where a new Renko bar will be printed
IF Flex Renko is used with the option "New Bar when exceeded"
Right now the study does not take into account for that extra tick
Thank you
[2018-03-18 20:30:51]
User120942 - Posts: 71
Is there a bar predictor study for Flex Renko Bars? The Renko Bar Predictor study does not display the correct area where a new bar will open. Please update the Renko Bar Predictor study or provide a new study to display tne starting point for the next bar.
Thank You
[2018-03-18 22:20:59]
gomifromparis - Posts: 244
If you can't it to work, you can have a look at GomRenko bars.
https://www.gomicators.com/gomrenko-sierra-chart/
They will give you predictor bars and you can enter one-click stop entries on the bars.
[2018-03-26 05:40:31]
This will be supported in the next release:
[2018-05-04 23:08:04]
Just following up on this question. Has this change been implemented for the Flex Renko study? I am currently on version 1738 but the renko bar predictor study still does not show the correct values for the next bar. Is this scheduled to happen in a future update? Just making sure I am not missing something.
Thank You
[2018-05-07 11:14:03]
Yes we have done some work on this study. There is no further work that is planned. To our knowledge there is no remaining issue.
Date Time Of Last Edit: 2018-05-07 11:14:16
