Date/Time: Sat, 25 Jan 2025 01:26:40 +0000
Sierra Chart doesn''t connect at my new work place
View Count: 1877
[2014-10-30 18:52:08]
User91641 - Posts: 13
I started work at a new place and Sierra Chart sits there with a yellowed line saying "Connecting...".
If you have any ideas to help me with that.
Best regards,
JF
[2014-10-30 19:43:28]
Provide a copy of the Message Log, by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#log
[2014-10-31 19:23:20]
Software version: 1173 | 2014-10-31 15:18:07
Usage end date: 2014-12-04 | 2014-10-31 15:18:07
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-10-31 15:18:07
Active service: Rithmic Trading | 2014-10-31 15:18:07
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-10-31 15:18:07
2014-10-31 12:18:07 Local computer clock time | 2014-10-31 15:18:07
2014-10-31 19:18:07 GMT time | 2014-10-31 15:18:07
2014-10-31 15:18:07 Time zone adjusted time | 2014-10-31 15:18:07
Time difference to server time: 8 seconds. | 2014-10-31 15:18:07
Program path: C:\SierraChart\ | 2014-10-31 15:18:07
Data Files path: C:\SierraChart\Data\ | 2014-10-31 15:18:07
OS Version Number: 6.1 | 2014-10-31 15:18:07
Checking for new symbol settings for rim | 2014-10-31 15:18:07
AsyncHTTP2 socket (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-10-31 15:18:11
AsyncHTTP2 socket (2092) | Connected. | 2014-10-31 15:18:12
Rithmic Trading | Port for executable: 58571 | 2014-10-31 15:18:12
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-31 15:18:12
Symbol settings are up-to-date for rim | 2014-10-31 15:18:12
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58571 | 2014-10-31 15:18:14
Socket (1168) | Connected. | 2014-10-31 15:18:14
Rithmic Trading | Connected to server. | 2014-10-31 15:18:14
Rithmic Trading | Sending logon request message. | 2014-10-31 15:18:14
Rithmic Trading | Starting the connection process to data and trading service. | 2014-10-31 15:18:14
Rithmic Trading | Logging is enabled. Log file: Rithmic.log | 2014-10-31 15:18:14
Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-10-31 15:18:14
AsyncHTTP2 socket (2092) | Closed. No error. | 2014-10-31 15:18:17
AsyncHTTP2 socket (2092) | Shutdown and closed. | 2014-10-31 15:18:17
Rithmic Trading | Error creating the main object. Error message: os error | 2014-10-31 15:19:27
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-10-31 15:19:27
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-10-31 15:19:27
Rithmic Trading | Logon error from server | 2014-10-31 15:19:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-31 15:19:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-31 15:19:27
Socket (1168) | Closed. No error. | 2014-10-31 15:19:27
Socket (1168) | Shutdown and closed. | 2014-10-31 15:19:27
Rithmic Trading | Disconnected from the server. | 2014-10-31 15:19:27
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-10-31 15:19:27
Rithmic Trading | Port for executable: 62923 | 2014-10-31 15:19:29
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-31 15:19:29
Rithmic Trading | Connecting to the server 127.0.0.1. Port 62923 | 2014-10-31 15:19:31
Socket (1164) | Connected. | 2014-10-31 15:19:31
Rithmic Trading | Connected to server. | 2014-10-31 15:19:31
Rithmic Trading | Sending logon request message. | 2014-10-31 15:19:31
Rithmic Trading | Starting the connection process to data and trading service. | 2014-10-31 15:19:31
Rithmic Trading | Logging is enabled. Log file: Rithmic.log | 2014-10-31 15:19:31
Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-10-31 15:19:31
Rithmic Trading | Error creating the main object. Error message: os error | 2014-10-31 15:20:44
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-10-31 15:20:44
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-10-31 15:20:44
Rithmic Trading | Logon error from server | 2014-10-31 15:20:44
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-31 15:20:44
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-31 15:20:44
Socket (1164) | Closed. No error. | 2014-10-31 15:20:44
Socket (1164) | Shutdown and closed. | 2014-10-31 15:20:44
Rithmic Trading | Disconnected from the server. | 2014-10-31 15:20:44
Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-10-31 15:20:44
Rithmic Trading | Port for executable: 1484 | 2014-10-31 15:20:47
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-31 15:20:47
Rithmic Trading | Connecting to the server 127.0.0.1. Port 1484 | 2014-10-31 15:20:49
Socket (1152) | Connected. | 2014-10-31 15:20:49
Rithmic Trading | Connected to server. | 2014-10-31 15:20:49
Rithmic Trading | Sending logon request message. | 2014-10-31 15:20:49
Rithmic Trading | Starting the connection process to data and trading service. | 2014-10-31 15:20:49
Rithmic Trading | Logging is enabled. Log file: Rithmic.log | 2014-10-31 15:20:49
Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-10-31 15:20:49
[2014-10-31 20:42:06]
The Rithmic software is giving you this error which is in bold:
We do not know why. Could be due to a firewall or something else.
This problem is documented at step 17 here:
Rithmic Trading Platform Service: Setup Instructions
Who is your broker?
[2014-11-01 17:15:20]
My broker is:
DORMAN TRADING
If this can help, when I am at work it doesn't work when I connect to their network but I if I connect to my iPhone hotspot it works well (but it's a real pain to have to juggle with connecting to their network and my iPhone and the fact that I'm on 3G all the time - it doesn't look like I can have hotspot through their Wifi)
Date Time Of Last Edit: 2014-11-03 20:16:52
[2014-11-03 20:16:36]
After trying to connect to Rithmic we need you to send us the Rithmic log file. This will be in C:\SierraChart\Rim. Send it to support _AT_ SierraChart.com.
We will then forward the file to Rithmic to comment on this.
[2014-11-04 16:22:42]
Thanks - I just sent the email with the log file - J. Rivard 760-447-1715
[2014-11-04 19:03:25]
We will send this to Rithmic.
[2014-11-04 20:51:36]
Based on the answer from Rithmic, this appears to be caused by a firewall on your computer network.
We cannot provide further help because we do not control the connection to Rithmic.
[2014-11-05 18:49:59]
Is Sierra using certain ports that we need to leave open in the firewall?
[2014-11-05 19:01:49]
It is not Sierra Chart which connects to Rithmic.
If that were the case, we would not even have to be contacting Rithmic about this to analyze a log file and you would never even get this cryptic error message:
"OS Error".
It is the Rithmic software which connects to the Rithmic system.
Here is some connection information used by the Rithmic software which might be helpful:
"MML_DMN_SRVR_ADDR=ritpz01001.01.rithmic.com:65000~ritpz01000.01.rithmic.com:65000~ritpz01001.01.rithmic.net:65000~ritpz01000.01.rithmic.net:65000~ritpz01001.01.theomne.net:65000~ritpz01000.01.theomne.net:65000~ritpz01001.01.theomne.com:65000~ritpz01000.01.theomne.com:65000"
  , "MML_DOMAIN_NAME=rithmic_prod_01_dmz_domain"
  , "MML_LIC_SRVR_ADDR=ritpz01000.01.rithmic.com:56000~ritpz01001.01.rithmic.com:56000~ritpz01000.01.rithmic.net:56000~ritpz01001.01.rithmic.net:56000~ritpz01000.01.theomne.net:56000~ritpz01001.01.theomne.net:56000~ritpz01000.01.theomne.com:56000~ritpz01001.01.theomne.com:56000"
  , "MML_LOC_BROK_ADDR=ritpz01000.01.rithmic.com:64100"
  , "MML_LOGGER_ADDR=ritpz01000.01.rithmic.com:45454"
Date Time Of Last Edit: 2014-11-05 19:02:39
[2019-02-11 23:24:11]
User476868 - Posts: 5
Just wondering whether you ever managed to solve the problem as I have had the exact same experience today.
Moved to a new office and SC goes down with the similar connection issue. From reading documentation, it appears likely to be a firewall issue but still don't know how to resolve.
Any suggestions very welcome!
[2019-02-12 01:04:23]
No. While Rithmic is supported, the decision has been made to cease all development with Rithmic.
We are working on a new service as an alternative for our Rithmic users that they can move to over time in the next 12 to 18 months.
We will have more information out about this, hopefully by the end of the week.
Date Time Of Last Edit: 2019-02-12 01:05:14
