Date/Time: Mon, 16 Sep 2024 19:42:28 +0000
Prior Study Collection
View Count: 852
[2014-10-30 00:45:14] |
User21113 - Posts: 62 |
The screen capture is from the morning of 9/18. Notice the study collection is being applied to the data on 9/18. The prior high, prior low and intra-day high and low are forming on the 9/18 data. This is expected. Notice the study is still applied on the 9/17 data. The expectation is that the study collection will be removed from the 9/17 data when the day turns to 9/18. The study collection is only removed from the 9/17 data when a new time frame is selected. What is the expected operation of this feature? |
[2014-10-30 01:58:31] |
We do not know what study you are using but what you describe does make sense. Study values which have already been calculated will not be cleared until the chart is reloaded.
