Date/Time: Fri, 22 Nov 2024 13:25:45 +0000
Adding stops and targets after entry
View Count: 1670
[2013-05-14 21:49:15] |
User23815 - Posts: 210 |
New User. I normally enter with attached orders. If I enter with just the entry order, how can I add stops and targets after the entry is filled and I have a position? When I try and enter from the trade window or the chart it puts in a new order with stops and targets attached. Thanks
[2013-05-14 22:25:38] |
Please see: http://www.sierrachart.com/index.php?l=doc/doc_OrderTypes.html#SendAttachedOrders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
