Date/Time: Thu, 28 Nov 2024 00:44:47 +0000
Orders are canceled immediately after being sent
View Count: 916
[2014-10-29 15:50:48]
snillumat - Posts: 29
I am using SC version 1206 and OEC.
When I try to execute a trade using a button in an attached chart trade window it cancels immediately and I get the followng error:
Trade Order Error - OEC order update (Rejected). Text: All TimeInForce fields must be equal.. Internal Order ID: 6542. Service Order ID: OECFIX:635487444335451356:142993. Symbol: ESZ4 | 2014-10-29 08:40:17 *
I understand that I can avoid this by disabling the "Use server side OCO and bracket orders" selection in the general trade settings.
However, I want the orders to be held on the server side. I thought OEC supported this.
[2014-10-29 17:23:11]
Make sure the Time In Force setting for the Attached Orders (Targets tab on the Trade Window) matches the Time In Force setting that you see on the Main tab of the Trade Window.
Refer to:
http://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#TimeInForce
[2014-10-29 17:30:30]
I have checked, double checked, triple checked ... they are all the same TIF
[2014-10-29 17:53:56]
And what are both of the Time in Force fields set to?
[2014-10-29 17:59:06]
Good til canceled
[2014-10-29 18:15:20]
It works for us.
You might be setting the Time in Force setting on the wrong Trade Window.
To make sure you are looking at the correct Trade Window, select Trade >>Open Trade Window for Chart.
