Date/Time: Fri, 31 Jan 2025 11:46:39 +0000
dom templates
View Count: 2915
[2014-10-29 10:14:05] |
User62940 - Posts: 15 |
hi ! How do I save my customize template for a dom to apply it to all the dom? tkx |
[2014-10-29 18:00:13] |
Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails20.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-03 02:16:06] |
User745789 - Posts: 356 |
Is it supported to save a Trade DOM column layout and then apply it to any DOM? Independent of chartbook. If I change the layout of one DOM, I want it automatically applied to all DOM's that use that layout. This goes beyond the global graphics settings for a Trade DOM. |
[2019-05-03 19:59:17] |
Not to an existing one. The closest that would be available is Chart Linking: Working With Charts: Chart Linking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-04 00:21:24] |
It would be very nice for a user to be able to save a default Trade DOM column layout so that every time they open a Trade DOM for a chart, it appears with the users desired column config. I open a lot of DOMs on the fly as a symbol comes into play. They always open with the wrong columns showing. So every single time I have to get a Trade DOM for a chart by copying another DOM using 'duplicate chart', then change the symbol in chart settings. |
[2019-05-04 19:30:11] |
John - SC Support - Posts: 37621 |
Refer to this section of the Chart Templates page for different ways of doing this: Using Chart Templates: Duplicating Charts / Template Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-05 00:43:02] |
Thank you for the support. I am well acquainted with that page. Unfortunately I do not find an answer to "saving Trading DOM column layouts as default."
[2019-05-05 13:39:24] |
There is no need for this and that will never come. Just follow step 6 here: Using Chart Templates: Duplicating Charts / Template Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
