Date/Time: Tue, 18 Feb 2025 22:33:17 +0000
help with New SpreadSheets
View Count: 913
[2014-10-28 22:30:50] |
david koresh - Posts: 6 |
Hello I need help with a New SpreadSheets I have some SpreadsheetStudy I work with and I wanted to know how I copy Value from one to another For example, in an old SpreadSheets I put the code ='[DefaultSpreadsheetStudy.scwbf]Sheet7'!$R$3 And it Be copying the value to another SpreadsheetStudy |
[2014-10-29 00:18:04] |
Sawtooth - Posts: 4173 |
Referencing another spreadsheet file is not supported in the New Spreadsheets version.
[2014-10-29 03:53:04] |
This is not supported. There are alternatives to this. More information about this is in this section here: https://www.sierrachart.com/index.php?page=doc/doc_Spreadsheets.html#DifferenceNewOldSpreadsheets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
