Date/Time: Thu, 28 Nov 2024 00:31:57 +0000
Study lines Moving Average too short
View Count: 917
[2014-10-28 22:07:18] |
User20361 - Posts: 6 |
Dear, In the attachment I send you a screenshot from two screens in Sierra Charts. On the first screen (left) the MA study lines are very short while on the right screen the MA study lines are normal. I use the same settings on both screens. What is the problem? Already thanks for you answer, Anita |
Screenshot.PNG / V - Attached On 2014-10-28 22:06:40 UTC - Size: 278.32 KB - 336 views Attachment Deleted. |
[2014-10-29 03:50:23] |
This is because there is not enough data in the chart. With Interactive Brokers and that particular symbol, there is really not a practical solution to this.
