Date/Time: Thu, 28 Nov 2024 00:29:42 +0000
Forex data feed that sends every tick
View Count: 1419
[2014-10-28 20:28:34] |
ticktrader - Posts: 5 |
Hi, I have an Forex study that is applied to a tick chart. I am using SC FX data feed. I have an indicator that plots the amount of ticks received per bar. I see the amount of ticks per bar received is less than the tick interval for each bar. I was wondering if this is due to the data feed or SC does not plot every tick. In my study I have the setting to update always equal to true. Is there any data feed that sends every tick? |
[2014-10-28 21:38:30] |
You can see the number of trades per bar by adding the Number of Trades study. The problem is with your study. You need to understand that the study function is not called at every trade. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ACS_ArraysAndLooping.html#WhenFunctionCalled Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-29 05:46:20
