Date/Time: Thu, 28 Nov 2024 00:32:06 +0000
Sierra charts connects to Continuum?
View Count: 1312
[2014-10-28 13:01:41] |
batman_ - Posts: 190 |
Continuum is the only CQG data feed and order routing provider in offering FIX with 3rd party program. Does sierra charts connecting to Continuum FIX? instead of CQG API? Please advice. TQ. |
[2014-10-28 17:06:46] |
Yes. Sierra Chart does support CQG FIX. But we are changing this to use what is called the web socket connection. In no case does Sierra Chart use the CQG proprietary API component. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
