Date/Time: Thu, 28 Nov 2024 00:24:24 +0000
Selecting OVerlapping Drawings
View Count: 1489
[2014-10-28 02:30:44] |
User56866 - Posts: 28 |
Hi If I have two tools on a chart and they overlap when I try to select one it will select both and a number will appear on each one, how can I choose which to select? Can I select by choosing the number of the tool I want to select? Thanks, Ben |
[2014-10-28 02:53:42] |
In this particular case you need to type the drawing number on the keyboard and press the Enter key to select it.
