Date/Time: Thu, 28 Nov 2024 00:49:00 +0000
Account status not updated since 2 1/2 hours
View Count: 909
[2014-10-27 20:21:17]
User77270 - Posts: 23
Dear sir or madam,
Around 2 1/2 hours ago I purchased a one-month service of you for package nr 3. The details in your website (my account management) are updated already, but SC software is still displaying "free mode" and thus I cannot connect to TWS. Could you please update the information in the SC software?
Thank you and kind regards,
Here's the log:
Software version: 1137 | 2014-10-27 19:39:11
Your usage time has ended. You are in FREE MODE. Features are restricted. | 2014-10-27 19:39:11
To purchase more time select Help>>Purchase on the menu. | 2014-10-27 19:39:11
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-10-27 19:39:11
Active service: Interactive Brokers | 2014-10-27 19:39:11
Time Zone: +00:00:00 (UTC+00) | 2014-10-27 19:39:11
2014-10-27 20:39:11 Local computer clock time | 2014-10-27 19:39:11
2014-10-27 19:39:11 GMT time | 2014-10-27 19:39:11
2014-10-27 19:39:11 Time zone adjusted time | 2014-10-27 19:39:11
Program path: C:\SierraChart\ | 2014-10-27 19:39:11
Data Files path: C:\SierraChart\Data\ | 2014-10-27 19:39:11
OS Version Number: 6.1 | 2014-10-27 19:39:11
Checking for new symbol settings for ib | 2014-10-27 19:39:11
HttpSendRequest failed: Windows error code 2: Das System kann die angegebene Datei nicht finden. | 2014-10-27 19:39:11
Request for symbol settings MD5 failed. | 2014-10-27 19:39:11
Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2014-10-27 19:39:16
[2014-10-27 20:43:45]
There is a problem connecting to the Sierra Chart Web server.
Refer to the Login Problems section here:
http://www.sierrachart.com/index.php?page=doc/LoginInstructions.php#LoginProblems
Most likely Internet Explorer is set to work off-line.
Once the problem is resolved, restart Sierra Chart and enable "Force Login" on the Login window.
Date Time Of Last Edit: 2014-10-27 20:44:00
[2014-10-27 21:09:19]
Thank you very much!
The problem was "off-line work" in Internet Explorer.
Thanks for the fast and helpful response.
