Date/Time: Thu, 28 Nov 2024 00:47:20 +0000
Bug in Session times: Start time, End time ?
View Count: 869
[2014-10-27 19:57:58] |
User59863 - Posts: 36 |
Only works on intraday timeframes Does not work on daily timeframe Eg if I set GMT time on FX intraday (1 hr, 30min..) it will work fine, opening session hrs will be 09:00 GMT. But on daily chart, opening hrs will still be EST time. So bug is that charts do not synchronize properly. |
[2014-10-27 20:03:52] |
Session Times cannot be set for historical Daily charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
