Date/Time: Mon, 16 Sep 2024 19:25:02 +0000
Different display of line
View Count: 809
[2014-10-27 19:05:04] |
User53601 - Posts: 105 |
Hello, Could you please help with this: I have a collection of studies. The line displayed by one of the study has different look in different graphs. Please look at the attached pictures which show the difference. I also attach the setting of the Subgraph. Jaro |
Line 01.png / V - Attached On 2014-10-27 19:04:45 UTC - Size: 20.1 KB - 327 views Line 02.png / V - Attached On 2014-10-27 19:04:50 UTC - Size: 15.93 KB - 330 views Setting.png / V - Attached On 2014-10-27 19:04:54 UTC - Size: 27.24 KB - 322 views |
[2014-10-30 05:11:15] |
We do not know the reason for this. The appearance of the line you apparently are referring to looks unusual to us. You are in a better position to make a determination as to the source of the problem. Remove all studies from the chart, and add one at a time, and make changes to the Study Subgraphs settings until you can determine the reason for the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-30 05:11:38
