Date/Time: Thu, 28 Nov 2024 00:39:22 +0000
Old and New spreadsheet on the same computer
View Count: 889
[2014-10-27 18:23:14] |
User787778 - Posts: 140 |
I need to be able to use the "old" spreadsheet version to trade, while I develop "new" spread sheet trading system, without having to pay for an additional licence. I don't want to run both versions simultaneously. |
[2014-10-27 19:51:34] |
For this you need to install two copies of Sierra Chart. One that uses Old Spreadsheets and one that uses New Spreadsheets. There is no other possibility. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-27 19:57:09] |
One thing we need to make clear is that you do not have to pay for another Sierra Chart account. You can install as many copies of Sierra Chart on a system as you want and use them all at the same time. This is documented here: http://www.sierrachart.com/index.php?page=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
