Date/Time: Thu, 28 Nov 2024 00:28:22 +0000
Source of candlestick timing?
View Count: 920
[2014-10-27 17:27:47] |
Tom Welling - Posts: 17 |
How does Sierra Chart know when to start a new candlestick on a chart? Does it use my computer's time or information received from the data feed? I'm curious because if it uses my computer's time and the time is not accurate, then my candlesticks will look different than everyone else. |
[2014-10-27 17:58:35] |
We see you are using TD Ameritrade. So in this case, the local computer clock is used for reliability. We have observed TD Ameritrade timestamps cannot be relied upon. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
