Date/Time: Sat, 18 Jan 2025 05:05:39 +0000
sc.GetOrderByIndex
View Count: 1400
[2014-10-27 16:25:14] |
User29404 - Posts: 4 |
Hallo, I have a problem with function sc.GetOrderByIndex(i, OrderDetails). This function return allways -1 (SCTRADING_ORDER_ERROR). When I use at the same moment sc.GetOrderByOrderID(15233, OrderDetails) this function return 1 |
[2014-10-27 16:51:02] |
Is there a difference between the symbol of the chart and the symbol of the order? What is the variable 'i' set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-27 17:11:23] |
Symbol of the chart and the symbol of the order is the same (RLM-MZ4). Variable i is increment (index) and begin from 0. |
[2014-10-28 03:35:46] |
As we suspected, we tested this and we found no problem. It worked properly. Here is a code example you can work with: SCSFExport scsf_ACSILTradingTest(SCStudyInterfaceRef sc) { //Define references to the Subgraphs and Inputs for easy reference SCSubgraphRef BuyEntrySubgraph = sc.Subgraph[0]; SCSubgraphRef BuyExitSubgraph = sc.Subgraph[1]; SCSubgraphRef SellEntrySubgraph = sc.Subgraph[2]; SCSubgraphRef SellExitSubgraph = sc.Subgraph[3]; SCInputRef Enabled = sc.Input[0]; if (sc.SetDefaults) { // Set the study configuration and defaults. sc.GraphName = "Trading Test"; BuyEntrySubgraph.Name = "Buy Entry"; BuyEntrySubgraph.DrawStyle = DRAWSTYLE_ARROWUP; BuyEntrySubgraph.PrimaryColor = RGB(0, 255, 0); BuyEntrySubgraph.LineWidth = 2; BuyEntrySubgraph.DrawZeros = false; BuyExitSubgraph.Name = "Buy Exit"; BuyExitSubgraph.DrawStyle = DRAWSTYLE_ARROWDOWN; BuyExitSubgraph.PrimaryColor = RGB(255, 128, 128); BuyExitSubgraph.LineWidth = 2; BuyExitSubgraph.DrawZeros = false; SellEntrySubgraph.Name = "Sell Entry"; SellEntrySubgraph.DrawStyle = DRAWSTYLE_ARROWDOWN; SellEntrySubgraph.PrimaryColor = RGB(255, 0, 0); SellEntrySubgraph.LineWidth = 2; SellEntrySubgraph.DrawZeros = false; SellExitSubgraph.Name = "Sell Exit"; SellExitSubgraph.DrawStyle = DRAWSTYLE_ARROWUP; SellExitSubgraph.PrimaryColor = RGB(128, 255, 128); SellExitSubgraph.LineWidth = 2; SellExitSubgraph.DrawZeros = false; Enabled.Name = "Enabled"; Enabled.SetYesNo(0); Enabled. SetDescription("This input enables the study and allows it to function. Otherwise, it does nothing."); // This is false by default. Orders will be simulated. sc.SendOrdersToTradeService = false; sc.AllowMultipleEntriesInSameDirection = true; //This must be equal to or greater than the order quantities you will be submitting orders for. sc.MaximumPositionAllowed = 10000; sc.SupportReversals = false; sc.AllowOppositeEntryWithOpposingPositionOrOrders = true; // This variable controls whether to use or not use attached orders that are configured on the Trade Window for the chart. sc.SupportAttachedOrdersForTrading = false; //This variable controls whether to use the "Use Attached Orders" setting on the Trade Window for the chart sc.UseGUIAttachedOrderSetting = false; sc.CancelAllOrdersOnEntriesAndReversals= false; sc.AllowEntryWithWorkingOrders = true; sc.CancelAllWorkingOrdersOnExit = true; sc.AllowOnlyOneTradePerBar = false; //This needs to be set to true when a trading study uses trading functions. sc.MaintainTradeStatisticsAndTradesData = true; sc.AutoLoop = true; sc.GraphRegion = 0; // During development set this flag to 1, so the DLL can be modified. When development is completed, set it to 0 to improve performance. sc.FreeDLL = 0; return; } //return; //These must be outside of the sc.SetDefaults code block sc.SupportTradingScaleIn = 1; sc.SupportTradingScaleOut = 0; if (!Enabled.GetYesNo()) return; if ( sc.LastCallToFunction ) return;//nothing to do // Run the below code only on the last bar if (sc.Index < sc.ArraySize-1) return; s_SCPositionData PositionData; sc.GetTradePosition( PositionData); if (PositionData.PositionQuantity== 0) { // Create an s_SCNewOrder object. s_SCNewOrder NewOrder; NewOrder.OrderQuantity = 1; NewOrder.OrderType = SCT_MARKET; NewOrder.TimeInForce = SCT_TIF_DAY; //Specify a Target and a Stop with 8 tick offsets. We are specifying one Target and one Stop, additional targets and stops can be specified as well. NewOrder.Target1Offset = 8*sc.TickSize; NewOrder.Stop1Offset = 8*sc.TickSize; NewOrder.OCOGroup1Quantity = 1; // If this is left at the default of 0, then it will be automatically set. int Result = sc.BuyEntry(NewOrder); if(Result > 0) { s_SCTradeOrder OrderDetails; Result = sc.GetOrderByIndex(0, OrderDetails); } } } Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-29 16:59:35] |
Thank You, your example code helped me to find my fault. I forgot the diference between Trade Simulation Mode and sc.SendOrdersToTradeService. Can you help me once more? I need get cash balance in the account for assessment of risk in my study. This is same value, you can see in Trade >> Trade orders and Positions >> Balance Date Time Of Last Edit: 2014-10-29 17:23:52
[2014-10-29 17:24:22] |
This is sc.TradeServiceAccountBalance
[2018-01-26 19:15:45] |
User14532 - Posts: 6 |
Hi I have a problem with the "GetOrderByIndex". In simulation mode it works well. If I switch to live (Interactive Broker). "GetOrderByIndex" does not return any result. Even though live orders are displayed in the "Orders And Positions" window. Can you help me? thank you. |
[2018-01-26 19:24:27] |
Refer to the documentation for this function: Automated Trading From an Advanced Custom Study: sc.GetOrderByIndex Always refer to the documentation. The documentation does explain how this function works. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-26 19:27:23
[2018-01-26 19:27:44] |
Prior post has now been made visible.
