Date/Time: Thu, 28 Nov 2024 00:39:32 +0000
Link Chart Drawing Objects
View Count: 1077
[2014-10-27 16:02:44] |
rwilliams1 - Posts: 346 |
Would it be possible to add the ability for drawing objects to be linked and shown on more than one chart similar to the Link Symbol, Link Bar Period, Link Scroll Position, etc? For example, drawing a horizontal support/resistance line in one chart that will also appear in its relative position on another chart would be very useful.
[2014-10-27 22:27:18] |
This capability already exists. Refer to the Chart Drawing Tools documentation.
