Date/Time: Thu, 28 Nov 2024 00:50:33 +0000
Shift chart to the left
View Count: 1827
[2014-10-27 04:47:28] |
Nazar - Posts: 6 |
Hi, Is there a way to shift chart to the left by a fixed number of bars such that it stays shifted during realtime data update? I have some studies which are rendered for the point of time in the future and I'd like to see them without having to manually shift the chart to the left with every new bar. Thanks. |
[2014-10-27 15:40:07] |
Sierra Chart - Max - Posts: 5732 |
Yes, you can Lock the Right Side Fill Space. Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ScrollingTheChart Sierra Chart Support |
[2014-10-27 16:10:25] |
Nazar - Posts: 6 |
Thank you, that is exactly what I was looking for
