Date/Time: Thu, 28 Nov 2024 00:37:44 +0000
Can't Connect To OEC
View Count: 1178
[2014-10-26 22:46:48]
User49270 - Posts: 48
Hi I can't seem to connect to Oec data. I checked with them and everything is fine on their side, and I am able to connect to the OEC Trader platform. Thanks
[2014-10-26 23:43:23]
snillumat - Posts: 29
same here
[2014-10-27 00:46:32]
We are contacting OEC about this now.
[2014-10-27 02:47:16]
OEC has changed the SSL version on the server which required a change in Sierra Chart.
This is now done. Update Sierra Chart with Help >> Download Prerelease. After the update you will be able to connect to OEC.
[2014-10-27 12:29:12]
StevieD - Posts: 39
Does this affect SierraChart versions BEFORE FIX was added?
I currently use SC v1077. Is this affected?
[2014-10-27 15:59:48]
No.
