Date/Time: Thu, 28 Nov 2024 00:47:34 +0000
Default Web Browser
View Count: 1397
[2014-10-26 15:46:26]
User17836 - Posts: 12
Is there a way to have Sierra use whatever the default browser is for the operating system? I use Chrome primarily and I get error messages for any web related functions unless I change the default system browser back to Firefox.
Error:
"This file does not have a program associated with it..."
[2014-10-27 03:03:28]
Sierra Chart does use the default browser. If there is a problem with this, it is happening at the operating system level. That particular error message you see originates from the operating system.
Make sure Chrome is properly registering itself as the default browser.
[2014-10-28 20:34:11]
Just checked & re-registered it as the default (win 8) Links from other applications are being opened in chrome. What else can I check?
image2014-10-28_16-31-21.jpg / V - Attached On 2014-10-28 20:33:42 UTC - Size: 189.35 KB - 443 views
