Date/Time: Thu, 28 Nov 2024 00:28:36 +0000
Local Support
View Count: 1137
[2014-10-24 11:36:32] |
User28317 - Posts: 149 |
I have a process that I would like to automate. Sierra Charts has been very helpful, however, I need help in putting all of the components together of my process. Can you refer me to someone in the Tampa/St.Petersburg area that can assist me in writing the code so I can automate my process?
[2014-10-24 17:54:36] |
Really our recommendation is that you do not need to have someone in your area. With remote assistance and a telephone connection or voice over IP connection, someone can connect to your computer and see your desktop and communicate with you, whether they are nearby or not. If it involves spreadsheets, see if they can help you: http://www.sawtoothtrade.com/ Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
