Date/Time: Thu, 28 Nov 2024 00:27:23 +0000
[User Discussion] - Symbol for NQ and ES emini contract continuous using SC Historical Data
View Count: 1679
[2014-10-23 18:49:16] |
User586214 - Posts: 6 |
I know there is simple answer but for some reason I just can't seem to find it. I need the symbol for the NQ and ES eminis, continuous contract. I am using SC Historical Data feed. In the past I was using ES# but that doesn't seem to work anymore. Seems to stop at January 2014. Thank you so much for your help. Garin |
[2014-10-24 05:26:57] |
Use the Continuous Futures Contract feature: http://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html Symbols that use the # do work but only with Historical Daily charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-24 05:27:13
[2014-10-24 15:27:40] |
Thank you! Garin |
