Date/Time: Thu, 28 Nov 2024 00:28:36 +0000
how to change the backgroud of the chart
View Count: 970
[2014-10-23 14:27:39] |
User47480 - Posts: 6 |
Dear friends: I use the " woodies for range char with PP " study, could you please tell me how to change the backgourd color in this study. i tried both in the chart->graphic setting and in the studies, but it doesn't work. Regards |
[2014-10-23 15:48:28] |
By default the Woodies study collection will do this. There is an Input setting to disable this in the Woodies Panel study. However, in the next release we will prevent the background color from being changed automatically.
