Date/Time: Thu, 28 Nov 2024 00:52:17 +0000
Attached Orders
View Count: 1015
[2014-10-23 14:20:57]
MsJackson - Posts: 27
Using v1199. In prior versions, I could modify my attached order line by dragging. This still works in sim mode. But in live trading, the order line just repositions to its original location after I drag and release.
[2014-10-23 15:17:45]
We see you are using OEC.
There should be an error message displayed in Trade >> Trade Service Log indicating the reason why the order modification is not working.
[2014-10-23 15:35:16]
This is all that is in the Trade Service Log
Trade Activity Log file read result: 65 records inserted. 0 records filtered. | 2014-10-23 07:50:15
Trade Activity Log file date-time limits: Sim record date-time limit is 2014-10-18 00:00:00. Non-sim record date-time limit is 2014-10-18 00:00:00. Non-sim fill record date-time limit is 2014-10-08 00:00:00. | 2014-10-23 07:50:15
[2014-10-23 15:38:26]
OK we understand.
You need to disable Trade >> General Trade Settings >> Use Server-Side OCO and Bracket Orders.
Date Time Of Last Edit: 2014-10-23 15:38:35
[2014-10-23 15:48:21]
Ok, that worked. Please explain why this option must be disabled. I thought OEC supports Server-side OCO and Bracket Orders.
[2014-10-23 15:49:24]
Because OEC does not support modifying Attached Orders that they manage.
[2014-10-23 15:53:10]
So if I modify the attached order, then it is no longer server-side supported?
[2014-10-23 15:59:27]
Not exactly like this. If you want to be able to modify an Attached Order, you need to disable the server side management of them.
