Date/Time: Fri, 22 Nov 2024 13:21:13 +0000
Total Commodity Volume & Total Commodity Open Interest
View Count: 3119
[2013-05-14 09:47:39] |
Paul.M - Posts: 113 |
I use CQG data as reference hereby. (I only looked at gold) Your Sierra History data for Total Commodity Volume & Total Commodity Open Interest is correct for DAILY (I only looked at gold). Your Sierra History data for Total Commodity Volume Weekly is correct. Your Sierra History data for Total Commodity Open Interest Weekly is NOT correct or calculated in a different way. Can you explain the difference please ? Your Sierra History data for Total Commodity Open Interest DAILY is not updated for yesterday. Can I adjust this somehow ? In general it is great that Sierra provides this data. TY |
OI-CQG-D.jpg / V - Attached On 2013-05-14 09:46:43 UTC - Size: 330.21 KB - 725 views OI-CQG-W.jpg / V - Attached On 2013-05-14 09:46:56 UTC - Size: 329.37 KB - 668 views OI-S-D.jpg / V - Attached On 2013-05-14 09:47:13 UTC - Size: 191.45 KB - 812 views OI-S-W.jpg / V - Attached On 2013-05-14 09:47:21 UTC - Size: 95.14 KB - 662 views |
[2013-05-14 18:00:04] |
The weekly open interest is the sum of the open interest from Monday through Friday. There should not be a problem with this. Unfortunately our data provider has delayed open interest data. The only thing you can try is to go to Edit >>Download Data-Historical Chart to bring the chart up-to-date with the latest available data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
