Date/Time: Thu, 28 Nov 2024 00:25:37 +0000
Terminal quotes in Spread Sheet to Sierra chart
View Count: 985
[2014-10-23 05:38:37] |
User48662 - Posts: 6 |
Hi, I have managed to get my terminal quotes to a spread sheet. but not sure how to load the same to Sierra chart. For eg I can load the same spreadsheet to Ambi broker or MT4 and get the chart. how can I do the same on sierra chart. Cheers |
[2014-10-24 01:15:11] |
Please let me know if this is possible
[2014-10-24 03:38:00] |
Refer to the text/CSV data format here: http://www.sierrachart.com/index.php?page=doc/doc_TextCSVDataFormat.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
