Date/Time: Thu, 28 Nov 2024 00:24:16 +0000
chart overlay
View Count: 959
[2014-10-23 03:35:43] |
User60436 - Posts: 19 |
Dear Support: I want to overlay two stock symbols and their studies (simple moving averages) in one chart to do comparison. For prices overlay, I use "Overlay Bar" study. For study overlay, I use "Study/Price overlay" study. Please see the attached chart. On the left chart, the top region shows BA monthly line prices (based on close price) and its 10 period simple moving average. In the left chart bottom region, I overlay SPY monthly line prices from chart 2 (from right chart) and its 10 period simple moving average. As you can see the SPY simple moving average in the bottom region of the left chart does not match that in the right chart. Could you tell what might be wrong? Thanks very much. P.S. My Sierra Chart version is 1202. The setting of "Study/Price overlay" is shown in the second attachment file. Inside this chart, the "Study to Overlay" value is #2.ID1, where #2 is the right chart number for SPY symbol, and ID1 is its 10 period simple moving average. |
ChartOverlayQ1.png / V - Attached On 2014-10-23 03:27:41 UTC - Size: 71.71 KB - 345 views ChartOverlayQ2.png / V - Attached On 2014-10-23 03:32:22 UTC - Size: 71.38 KB - 323 views |
[2014-10-23 04:53:07] |
This is because the studies are not both set to use an "Automatic" Scale Range: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-23 04:53:49
