Date/Time: Thu, 28 Nov 2024 00:51:10 +0000
"Go Back" is preferrable to adding "confirmation" for actions
View Count: 890
[2014-10-22 23:41:53] |
nicker1 - Posts: 10 |
Many times I have wished that SC had a back arrow to return to previous screen before I changed something. It would have saved a lot of work where instead I may have to start completely over because I cannot back up just one step. Now SC has complicated erasing all lines by making me stop to confirm. I don't want that time taken during the trading day. To me it would be far preferable to use a "go back" button if I err, instead of having to "confirm" what I usually do right. Please could you remove the irritating confirmation for erasures. Pleaser would you add a "go back" button? Twould be awesome. Thanks very much |
[2014-10-23 02:01:32] |
The confirmation can be disabled through Global Settings >> Tool Settings.
