Date/Time: Thu, 28 Nov 2024 00:39:39 +0000
Reloaded charts to new computer and cant find old set ups
View Count: 902
[2014-10-22 19:33:44] |
User534624 - Posts: 3 |
I had to reload Sierra to a new computer. We saved the charts in a new hard drive. After installing Sierra to the new computer, I found the old charts I set up. Saved them when closing . Now when I open up the charts, my charts to not load, are not listed under Chart books and I don't know where to find them. Any advice? Thanks!
[2014-10-22 22:24:28] |
So you do not see them when you select File >> Open Chartbook. Refer to help topic 15 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Let us know if you need more help. Your Chartbooks need to be put in the Global Settings >> General Settings >> Data Files Folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-23 04:49:28] |
Found them! thank you! :)
