Date/Time: Thu, 28 Nov 2024 00:51:35 +0000
pre set target/ stops
View Count: 1081
[2014-10-22 17:47:33] |
Tlaw1 - Posts: 15 |
Hello guys. I was wondering if there was a way to save preset targets and stops. for example in ninja trader there is a way to set ATM strategy for stop, target1, target2, move stop to Break even, etc... i can set one for a trade that needs an 8 tick stop and targets, 10 tick stops, 12, etc. so when i go to place a trade limit order i just know my stop and choose the preset based on that amount of risk.... is there such thing on Sierra chart to so this? i know i can set up the stop and targets but im having to change them on the fly and missing scalp trades i can otherwise take if i had the trade manager preset. let me know if this is making sense? thanks a lot. have a great day. cheers, Tlaw |
[2014-10-23 04:48:02] |
This feature is called Trade Window Configurations and is documented here: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#TradeWindowConfigurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
