Date/Time: Thu, 28 Nov 2024 00:44:18 +0000
IB Depth with IQFeed data
View Count: 1383
[2014-10-22 16:01:25]
joshtrader - Posts: 488
Attached is my config for two DOMs, both opened from an IB copy of SC. Left DOM uses a remote IQFeed data instance for chart data, and is using the IB data as an alternate source. Why am I not getting depth for the DOM on the left? In the right DOM, it is using IB for all data and it has depth.
In both copies of SC I have the General Settings->"Use Non Chart Data From Remote Instances" set to True.
I can place orders correctly using the DOM config on the left, by the way, so it seems to be working fine except no depth.
Date Time Of Last Edit: 2014-10-22 16:03:40
Private File
[2014-10-22 16:11:59]
When you go to the instance of Sierra Chart connected to IQ Feed and open a chart for that symbol you are not getting depth for and select Chart >> Open Market Depth Window, do you see market depth?
[2014-10-22 17:17:52]
User25244 - Posts: 123
I dont
[2014-10-22 18:09:00]
No, I don't because I don't subscribe to depth through IQFeed... I do get it from IB though, and I would think that would come from IB with the config I posted previously.
[2014-10-22 20:23:31]
Uncheck this:
Global Settings >> General Settings >>Use Non Chart Data From Remote Instances.
After that reconnect to the data feed with the Disconnect and Connect commands on the File menu.
[2014-10-22 20:26:40]
This fixed the problem -- I read the syntax of the option incorrectly, as I see now it was trying to pull depth from IQFeed when it was not there. Sorry for the noobish question.
Date Time Of Last Edit: 2014-10-22 20:26:56
