Date/Time: Thu, 28 Nov 2024 00:35:08 +0000
Sierra charts are not working after upgradation
View Count: 906
[2014-10-22 04:45:01] |
User38813 - Posts: 20 |
sir i am not able to open sierra charts after upgrading the latest version. Click on logo does not open it up. i tries to open/run it as a admin. but not able to open it up. pls guide me how to open it up
Date Time Of Last Edit: 2014-10-22 04:45:40
[2014-10-22 07:28:22] |
Make sure you install the version with New Spreadsheets. Here is the link to the installer: https://www.sierrachart.com/downloads/SierraChartSetupNoCLR.exe Once you install this version, Sierra Chart will start. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-22 07:31:22
