Date/Time: Fri, 22 Nov 2024 18:28:18 +0000
[User Discussion] - Highest High Lowest Low over N bars question
View Count: 1978
[2013-05-14 01:16:34]
User22396 - Posts: 191
Is there a setting for this indicator to output only when the current bar is complete?
For example i have a 1-day 'intraday chart only' diplaying a custom session when i place this study with N=3 it removes the 3rd day when the new day starts...so in a sense makes the current day part of the study...
[2013-05-26 19:46:56]
hello support...any feedback?
thanks
[2013-05-26 20:22:20]
Sawtooth - Posts: 4118
There is no option in that study to do what you want, but it can be done with the Spreadsheet Study study.
Add the Spreadsheet Study study, give it a name in the Spreadsheet Name field, and set the Chart Region to 1.
For the Highest High, put this in K3:
=IF(ROW()=3,0,AA3)
For the Lowest Low, put this in L3:
=IF(ROW()=3,0,AB3)
This assumes the HH/LL Over N Bars study is in columns AA and AB. Edit column references as needed.
Then check Hide Study on the HH/LL over N Bars study.
[2013-05-26 20:41:55]
thanks tom...will give it a go
