Date/Time: Thu, 28 Nov 2024 00:29:58 +0000
Toolbar - Chart bar period - Flex renko bar period - "New bar when exceeded"
View Count: 1342
[2014-10-21 19:57:25]
N!co - Posts: 140
Global settings --> Customize toolbar --> Chart bar period --> Custom bar period
Could you please add the option "New bar when exceeded" when Flex Renko is selected as custom bar period
Right now this option is not available and this makes that is is imposible to have flex renko bar periodes like
1-0-0
3-0-0
5-0-0
because these will be seen as normal renko periods, but these are NOT the same as normal renko period when "New bar when exceeded"
is selected
Thank you very much
[2014-10-23 05:11:01]
Why not just enable the option in Chart >> Chart Settings?
We cannot add this command to the ToolBar button configuration.
[2014-10-23 07:02:32]
N!co - Posts: 140
The idea of the toolbar button is to switch quickly from one timeframe to the other
going into the charts settings to change the renko to flexrenko and then enable the option "New bar when exceeded" aswell
is just way to much in order to quicky "scroll" many flexrenko timeframes,
the toolbar buttons are excelent for this
