Date/Time: Tue, 18 Feb 2025 21:55:55 +0000
Hot Key for "Go To" function on Spreadsheets?
View Count: 945
[2014-10-21 16:37:55]
The Stealthy Trader - Posts: 188
Was wondering if there was a more user friendly way of going from one window to another in the spreadsheets?
With over 150 windows, my fingers are wearing out from hitting the < > keys in rapid fire.
The right click "Go To" option is barely an improvement as we have to fiddle around with spreadsheet linguistics.
Any way you guys/gals can create a simple internal converter where all us users have to do is type in a box(that's readily viewable/accessible) the Window #(no other input required) we desire, hit enter and that window's tab is now centered in the view.
This would be a huge User Interface improvement as I'm sure many of us are zipping around these spreadsheets all day long.
Thanks in advance,
Jonathan's Overused Index Finger
Date Time Of Last Edit: 2014-10-21 17:04:53
[2014-10-22 00:43:49]
Are you referring to jumping to a particular Sheet # within a Spreadsheet window?
[2014-10-22 01:46:14]
Yes I am..
I'm sure a lot of your clients zip from one window to another all day long within any particular Spreadsheet.
The "Go To" option is clunky and barely faster than manually banging on the arrows in rapid fire..especially since it requires more than entering just the Window #.
It would be a huge time savings, which as I'm sure you're aware is desirable in this business, if you add a box(accessible right there at the bottom of the Window), that will only require us inputting the desired Window # and nothing else...
This way we could "fly" from Window #1 - #110 - #67 and back to #1 in a fraction of the time presently required.
Would be so huge...........
Date Time Of Last Edit: 2014-10-22 01:49:42
[2014-10-22 04:37:32]
We are no longer doing any development on the Old Spreadsheets and it sounds like you are using those.
But for the New Spreadsheets, we will support quickly jumping to a sheet as you manually type the number of the sheet in the list box which lists all of the Sheets.
