Date/Time: Thu, 28 Nov 2024 00:52:01 +0000
$VIX No Longer Updating
View Count: 997
[2014-10-21 14:37:36] |
User49270 - Posts: 48 |
Hi, my chart of the $VIX stopped updating 16:15est on 10/17/14 before that it was fine. All my other charts including Tick-NYSE and NVOL-NYSE are all fine. Any help would be appreciated. Thank You
[2014-10-21 17:19:10] |
You are not subscribing to the Sierra Chart Real-time and Historical Exchange Data Feed which provides this data. This is why it will not update. To use this data feed refer to this page: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-26 23:45:32] |
Thank you for your help
