Date/Time: Wed, 27 Nov 2024 22:43:06 +0000
MA
View Count: 844
[2014-10-21 13:48:01] |
User84098 - Posts: 5 |
how do I set a simple moving average to 20 days on a 60 minute chart?
[2014-10-21 19:57:33] |
mkata - Posts: 103 |
Set up two charts, a Daily and 60m. Then use Study/Price Overlay to put the daily 20sma on the 60m chart.
[2014-10-21 20:08:37] |
You will need to charts for this. Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
