Date/Time: Wed, 27 Nov 2024 22:45:54 +0000
unable to connect to sierra using ritmic-optimus demo account
View Count: 1011
[2014-10-21 12:30:39]
budy123 - Posts: 1
Hi there, any advice about this situation? thanks for helping.
Software version: 1202 | 2014-10-21 19:16:38
Usage end date: 2014-12-02 | 2014-10-21 19:16:38
Enabled for: Advanced Features. | 2014-10-21 19:16:38
Enabled for: Sierra Chart Historical Data Service. | 2014-10-21 19:16:38
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-10-21 19:16:38
Active service: Rithmic Trading | 2014-10-21 19:16:38
Time Zone: +07:00:00 (WIT+07) | 2014-10-21 19:16:38
2014-10-21 19:16:38 Local computer clock time | 2014-10-21 19:16:38
2014-10-21 12:16:38 GMT time | 2014-10-21 19:16:38
2014-10-21 19:16:38 Time zone adjusted time | 2014-10-21 19:16:38
Time difference to server time: 0 seconds. | 2014-10-21 19:16:38
Program path: C:\SierraChart\ | 2014-10-21 19:16:38
Data Files path: C:\SierraChart\Data\ | 2014-10-21 19:16:38
OS Version Number: 6.1 | 2014-10-21 19:16:38
Locale Information: English_United States.1252 | 2014-10-21 19:16:38
Checking for new symbol settings for rim | 2014-10-21 19:16:38
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-10-21 19:16:38
HTTP connection to www.sierrachart.com:80 (1108) | Connected. | 2014-10-21 19:16:38
Symbol settings are up-to-date for rim | 2014-10-21 19:16:38
Rithmic Trading | Port for executable: 59487 | 2014-10-21 19:16:43
Listening socket (1580), port 59487 | Closed. | 2014-10-21 19:16:43
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-21 19:16:43
HTTP connection to www.sierrachart.com:80 (1108) | Closed. No error. | 2014-10-21 19:16:44
HTTP connection to www.sierrachart.com:80 (1108) | Shutdown and closed. | 2014-10-21 19:16:44
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59487 | 2014-10-21 19:16:45
Socket (1112) | Connected. | 2014-10-21 19:16:45
Rithmic Trading | Connected to server. | 2014-10-21 19:16:45
Rithmic Trading | Sending logon request message. | 2014-10-21 19:16:45
Rithmic Trading | Starting the connection process to data and trading service. | 2014-10-21 19:16:45
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-10-21 19:16:45
Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-10-21 19:16:45
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-10-21 19:16:49
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-10-21 19:16:49
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-10-21 19:16:49
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-10-21 19:16:49
Rithmic Trading | Logon error from server | 2014-10-21 19:16:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:16:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:16:49
Socket (1112) | Shutdown and closed. | 2014-10-21 19:16:49
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:16:49
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:16:49
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:16:51
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59487 | 2014-10-21 19:16:53
Socket (1108) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:16:54
Socket (1108) | Shutdown and closed. | 2014-10-21 19:16:54
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:16:54
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:16:54
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:16:54
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:16:54
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:16:56
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59487 | 2014-10-21 19:16:58
Socket (1112) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:16:59
Socket (1112) | Shutdown and closed. | 2014-10-21 19:16:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:16:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:16:59
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:16:59
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:16:59
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:17:01
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59487 | 2014-10-21 19:17:03
Socket (1108) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:17:04
Socket (1108) | Shutdown and closed. | 2014-10-21 19:17:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:17:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:17:04
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:17:04
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:17:04
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:17:06
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59487 | 2014-10-21 19:17:08
Socket (1112) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:17:09
Socket (1112) | Shutdown and closed. | 2014-10-21 19:17:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:17:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:17:09
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:17:09
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:17:09
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:17:11
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59487 | 2014-10-21 19:17:13
Socket (1108) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:17:14
Socket (1108) | Shutdown and closed. | 2014-10-21 19:17:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:17:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:17:14
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:17:14
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:17:14
Rithmic Trading | Port for executable: 59506 | 2014-10-21 19:17:16
Listening socket (1588), port 59506 | Closed. | 2014-10-21 19:17:16
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-21 19:17:16
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59506 | 2014-10-21 19:17:18
Socket (1588) | Connected. | 2014-10-21 19:17:18
Rithmic Trading | Connected to server. | 2014-10-21 19:17:18
Rithmic Trading | Sending logon request message. | 2014-10-21 19:17:18
Rithmic Trading | Starting the connection process to data and trading service. | 2014-10-21 19:17:18
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-10-21 19:17:18
Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-10-21 19:17:18
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-10-21 19:17:23
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-10-21 19:17:23
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-10-21 19:17:23
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-10-21 19:17:23
Rithmic Trading | Logon error from server | 2014-10-21 19:17:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:17:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:17:23
Socket (1588) | Shutdown and closed. | 2014-10-21 19:17:23
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:17:23
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:17:23
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:17:25
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59506 | 2014-10-21 19:17:27
Socket (1568) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:17:28
Socket (1568) | Shutdown and closed. | 2014-10-21 19:17:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:17:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:17:28
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:17:28
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:17:28
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:17:30
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59506 | 2014-10-21 19:17:32
Socket (1588) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:17:33
Socket (1588) | Shutdown and closed. | 2014-10-21 19:17:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:17:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:17:33
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:17:33
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:17:33
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:17:35
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59506 | 2014-10-21 19:17:37
Socket (1568) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:17:38
Socket (1568) | Shutdown and closed. | 2014-10-21 19:17:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:17:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:17:38
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:17:38
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:17:38
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:17:40
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59506 | 2014-10-21 19:17:42
Socket (744) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:17:43
Socket (744) | Shutdown and closed. | 2014-10-21 19:17:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:17:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:17:43
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:17:43
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:17:43
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:17:45
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59506 | 2014-10-21 19:17:47
Socket (748) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:17:48
Socket (748) | Shutdown and closed. | 2014-10-21 19:17:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:17:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:17:48
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:17:48
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:17:48
Rithmic Trading | Port for executable: 59584 | 2014-10-21 19:17:50
Listening socket (1112), port 59584 | Closed. | 2014-10-21 19:17:50
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-21 19:17:50
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59584 | 2014-10-21 19:17:52
Socket (1112) | Connected. | 2014-10-21 19:17:52
Rithmic Trading | Connected to server. | 2014-10-21 19:17:52
Rithmic Trading | Sending logon request message. | 2014-10-21 19:17:52
Rithmic Trading | Starting the connection process to data and trading service. | 2014-10-21 19:17:52
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-10-21 19:17:52
Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-10-21 19:17:52
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-10-21 19:17:56
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-10-21 19:17:56
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-10-21 19:17:56
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-10-21 19:17:56
Rithmic Trading | Logon error from server | 2014-10-21 19:17:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:17:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:17:56
Socket (1112) | Shutdown and closed. | 2014-10-21 19:17:56
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:17:56
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:17:56
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:17:58
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59584 | 2014-10-21 19:18:00
Socket (696) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:18:01
Socket (696) | Shutdown and closed. | 2014-10-21 19:18:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:18:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:18:01
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:18:01
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:18:01
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:18:03
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59584 | 2014-10-21 19:18:05
Socket (1112) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:18:06
Socket (1112) | Shutdown and closed. | 2014-10-21 19:18:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:18:06
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:18:06
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:18:06
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:18:06
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:18:08
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59584 | 2014-10-21 19:18:10
Socket (696) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:18:11
Socket (696) | Shutdown and closed. | 2014-10-21 19:18:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:18:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:18:11
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:18:11
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:18:11
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:18:13
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59584 | 2014-10-21 19:18:15
Socket (1112) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:18:16
Socket (1112) | Shutdown and closed. | 2014-10-21 19:18:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:18:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:18:16
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:18:16
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:18:16
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:18:18
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59584 | 2014-10-21 19:18:20
Socket (696) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:18:21
Socket (696) | Shutdown and closed. | 2014-10-21 19:18:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:18:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:18:21
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:18:21
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:18:21
Rithmic Trading | Port for executable: 59601 | 2014-10-21 19:18:23
Listening socket (744), port 59601 | Closed. | 2014-10-21 19:18:23
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-21 19:18:23
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59601 | 2014-10-21 19:18:25
Socket (744) | Connected. | 2014-10-21 19:18:25
Rithmic Trading | Connected to server. | 2014-10-21 19:18:25
Rithmic Trading | Sending logon request message. | 2014-10-21 19:18:25
Rithmic Trading | Starting the connection process to data and trading service. | 2014-10-21 19:18:25
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-10-21 19:18:25
Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-10-21 19:18:25
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-10-21 19:18:29
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-10-21 19:18:29
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-10-21 19:18:29
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-10-21 19:18:29
Rithmic Trading | Logon error from server | 2014-10-21 19:18:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:18:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:18:29
Socket (744) | Shutdown and closed. | 2014-10-21 19:18:29
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:18:29
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:18:29
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:18:31
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59601 | 2014-10-21 19:18:33
Socket (748) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:18:34
Socket (748) | Shutdown and closed. | 2014-10-21 19:18:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:18:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:18:34
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:18:34
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:18:34
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:18:36
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59601 | 2014-10-21 19:18:38
Socket (1588) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:18:39
Socket (1588) | Shutdown and closed. | 2014-10-21 19:18:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:18:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:18:39
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:18:39
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:18:39
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:18:41
Using proxy for http request. | 2014-10-21 19:18:43
The above has been sent to support. | 2014-10-21 19:18:43 *
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59601 | 2014-10-21 19:18:43
Socket (1588) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:18:44
Socket (1588) | Shutdown and closed. | 2014-10-21 19:18:44
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:18:44
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:18:44
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:18:44
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:18:44
Sending of the message log was completed. Please read the response that was received. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2014-10-21 19:18:46
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:18:46
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59601 | 2014-10-21 19:18:48
Socket (1672) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:18:50
Socket (1672) | Shutdown and closed. | 2014-10-21 19:18:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:18:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:18:50
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:18:50
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:18:50
Rithmic Trading | Port for executable: 59649 | 2014-10-21 19:18:52
Listening socket (1112), port 59649 | Closed. | 2014-10-21 19:18:52
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-21 19:18:52
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59649 | 2014-10-21 19:18:54
Socket (1112) | Connected. | 2014-10-21 19:18:54
Rithmic Trading | Connected to server. | 2014-10-21 19:18:54
Rithmic Trading | Sending logon request message. | 2014-10-21 19:18:54
Rithmic Trading | Starting the connection process to data and trading service. | 2014-10-21 19:18:54
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-10-21 19:18:54
Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-10-21 19:18:54
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-10-21 19:18:57
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-10-21 19:18:58
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-10-21 19:18:58
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-10-21 19:18:58
Rithmic Trading | Logon error from server | 2014-10-21 19:18:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:18:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:18:58
Socket (1112) | Shutdown and closed. | 2014-10-21 19:18:58
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:18:58
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:18:58
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:19:00
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59649 | 2014-10-21 19:19:02
Socket (1756) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:19:03
Socket (1756) | Shutdown and closed. | 2014-10-21 19:19:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:19:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:19:03
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:19:03
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:19:03
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:19:05
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59649 | 2014-10-21 19:19:07
Socket (1112) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:19:08
Socket (1112) | Shutdown and closed. | 2014-10-21 19:19:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:19:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:19:08
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:19:08
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:19:08
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:19:10
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59649 | 2014-10-21 19:19:12
Socket (696) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:19:13
Socket (696) | Shutdown and closed. | 2014-10-21 19:19:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:19:13
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:19:13
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:19:13
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:19:13
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:19:15
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59649 | 2014-10-21 19:19:17
Socket (700) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:19:18
Socket (700) | Shutdown and closed. | 2014-10-21 19:19:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:19:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:19:18
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:19:18
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:19:18
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:19:20
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59649 | 2014-10-21 19:19:22
Socket (696) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:19:23
Socket (696) | Shutdown and closed. | 2014-10-21 19:19:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:19:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:19:23
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:19:23
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:19:23
Rithmic Trading | Port for executable: 59667 | 2014-10-21 19:19:25
Listening socket (1680), port 59667 | Closed. | 2014-10-21 19:19:25
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-21 19:19:25
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59667 | 2014-10-21 19:19:27
Socket (1680) | Connected. | 2014-10-21 19:19:27
Rithmic Trading | Connected to server. | 2014-10-21 19:19:27
Rithmic Trading | Sending logon request message. | 2014-10-21 19:19:27
Rithmic Trading | Starting the connection process to data and trading service. | 2014-10-21 19:19:27
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-10-21 19:19:27
Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-10-21 19:19:27
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-10-21 19:19:31
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-10-21 19:19:31
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-10-21 19:19:31
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-10-21 19:19:31
Rithmic Trading | Logon error from server | 2014-10-21 19:19:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:19:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:19:31
Socket (1680) | Shutdown and closed. | 2014-10-21 19:19:31
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:19:31
Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:19:31
Rithmic Trading | Port for executable: 59688 | 2014-10-21 19:20:20
Listening socket (696), port 59688 | Closed. | 2014-10-21 19:20:20
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-21 19:20:20
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59688 | 2014-10-21 19:20:22
Socket (696) | Connected. | 2014-10-21 19:20:22
Rithmic Trading | Connected to server. | 2014-10-21 19:20:22
Rithmic Trading | Sending logon request message. | 2014-10-21 19:20:22
Rithmic Trading | Starting the connection process to data and trading service. | 2014-10-21 19:20:22
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-10-21 19:20:22
Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-10-21 19:20:22
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-10-21 19:20:25
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-10-21 19:20:26
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-10-21 19:20:26
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-10-21 19:20:26
Rithmic Trading | Logon error from server | 2014-10-21 19:20:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:20:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:20:26
Socket (696) | Shutdown and closed. | 2014-10-21 19:20:26
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:20:26
Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:20:26
Rithmic Trading | Port for executable: 59716 | 2014-10-21 19:23:26
Listening socket (796), port 59716 | Closed. | 2014-10-21 19:23:26
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-21 19:23:26
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59716 | 2014-10-21 19:23:28
Socket (796) | Connected. | 2014-10-21 19:23:28
Rithmic Trading | Connected to server. | 2014-10-21 19:23:28
Rithmic Trading | Sending logon request message. | 2014-10-21 19:23:28
Rithmic Trading | Starting the connection process to data and trading service. | 2014-10-21 19:23:28
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-10-21 19:23:28
Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-10-21 19:23:28
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-10-21 19:23:32
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-10-21 19:23:32
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-10-21 19:23:32
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-10-21 19:23:32
Rithmic Trading | Logon error from server | 2014-10-21 19:23:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:23:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:23:32
Socket (796) | Shutdown and closed. | 2014-10-21 19:23:32
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:23:32
Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:23:32
Current selected Data/Trading service: Rithmic Trading | 2014-10-21 19:24:10
Rithmic Trading | Port for executable: 59727 | 2014-10-21 19:24:14
Listening socket (1756), port 59727 | Closed. | 2014-10-21 19:24:14
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-21 19:24:14
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59727 | 2014-10-21 19:24:16
Socket (748) | Connected. | 2014-10-21 19:24:16
Rithmic Trading | Connected to server. | 2014-10-21 19:24:16
Rithmic Trading | Sending logon request message. | 2014-10-21 19:24:16
Rithmic Trading | Starting the connection process to data and trading service. | 2014-10-21 19:24:16
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-10-21 19:24:16
Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-10-21 19:24:16
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-10-21 19:24:20
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-10-21 19:24:20
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-10-21 19:24:20
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-10-21 19:24:20
Rithmic Trading | Logon error from server | 2014-10-21 19:24:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:24:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:24:20
Socket (748) | Shutdown and closed. | 2014-10-21 19:24:20
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:24:20
Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:24:20
Current selected Data/Trading service: Rithmic Trading | 2014-10-21 19:25:12
Rithmic Trading | Port for executable: 59739 | 2014-10-21 19:25:18
Listening socket (696), port 59739 | Closed. | 2014-10-21 19:25:18
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-21 19:25:18
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59739 | 2014-10-21 19:25:20
Socket (696) | Connected. | 2014-10-21 19:25:20
Rithmic Trading | Connected to server. | 2014-10-21 19:25:20
Rithmic Trading | Sending logon request message. | 2014-10-21 19:25:20
Rithmic Trading | Starting the connection process to data and trading service. | 2014-10-21 19:25:20
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-10-21 19:25:20
Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-10-21 19:25:20
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-10-21 19:25:24
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-10-21 19:25:24
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-10-21 19:25:24
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-10-21 19:25:24
Rithmic Trading | Logon error from server | 2014-10-21 19:25:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:25:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:25:24
Socket (696) | Shutdown and closed. | 2014-10-21 19:25:24
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:25:24
Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:25:24
File >> Disconnect selected. | 2014-10-21 19:25:48
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:25:48
Current selected Data/Trading service: Rithmic Trading | 2014-10-21 19:26:04
Rithmic Trading | Port for executable: 59765 | 2014-10-21 19:26:08
Listening socket (1756), port 59765 | Closed. | 2014-10-21 19:26:08
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-21 19:26:08
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59765 | 2014-10-21 19:26:10
Socket (1756) | Connected. | 2014-10-21 19:26:10
Rithmic Trading | Connected to server. | 2014-10-21 19:26:10
Rithmic Trading | Sending logon request message. | 2014-10-21 19:26:10
Rithmic Trading | Starting the connection process to data and trading service. | 2014-10-21 19:26:10
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-10-21 19:26:10
Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-10-21 19:26:10
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-10-21 19:26:13
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-10-21 19:26:14
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-10-21 19:26:14
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-10-21 19:26:14
Rithmic Trading | Logon error from server | 2014-10-21 19:26:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:26:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:26:14
Socket (1756) | Shutdown and closed. | 2014-10-21 19:26:14
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:26:14
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:26:14
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:26:16
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59765 | 2014-10-21 19:26:18
Socket (1668) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:26:19
Socket (1668) | Shutdown and closed. | 2014-10-21 19:26:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:26:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:26:19
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:26:19
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:26:19
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:26:21
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59765 | 2014-10-21 19:26:23
Socket (1668) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:26:24
Socket (1668) | Shutdown and closed. | 2014-10-21 19:26:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:26:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:26:24
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:26:24
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:26:24
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:26:26
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59765 | 2014-10-21 19:26:28
Socket (796) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:26:29
Socket (796) | Shutdown and closed. | 2014-10-21 19:26:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:26:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:26:29
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:26:29
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:26:29
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:26:31
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59765 | 2014-10-21 19:26:33
Socket (1668) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:26:34
Socket (1668) | Shutdown and closed. | 2014-10-21 19:26:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:26:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:26:34
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:26:34
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:26:34
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:26:36
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59765 | 2014-10-21 19:26:38
Socket (700) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:26:39
Socket (700) | Shutdown and closed. | 2014-10-21 19:26:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:26:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:26:39
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:26:39
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:26:39
Rithmic Trading | Port for executable: 59784 | 2014-10-21 19:26:41
Listening socket (800), port 59784 | Closed. | 2014-10-21 19:26:41
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-21 19:26:41
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59784 | 2014-10-21 19:26:43
Socket (800) | Connected. | 2014-10-21 19:26:43
Rithmic Trading | Connected to server. | 2014-10-21 19:26:43
Rithmic Trading | Sending logon request message. | 2014-10-21 19:26:43
Rithmic Trading | Starting the connection process to data and trading service. | 2014-10-21 19:26:43
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-10-21 19:26:43
Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-10-21 19:26:43
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-10-21 19:26:47
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-10-21 19:26:47
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-10-21 19:26:47
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-10-21 19:26:47
Rithmic Trading | Logon error from server | 2014-10-21 19:26:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:26:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:26:47
Socket (800) | Shutdown and closed. | 2014-10-21 19:26:47
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:26:47
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:26:47
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:26:49
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59784 | 2014-10-21 19:26:51
Socket (748) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:26:52
Socket (748) | Shutdown and closed. | 2014-10-21 19:26:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:26:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:26:52
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:26:52
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:26:52
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:26:54
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59784 | 2014-10-21 19:26:56
Socket (800) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:26:57
Socket (800) | Shutdown and closed. | 2014-10-21 19:26:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:26:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:26:57
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:26:57
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:26:57
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:26:59
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59784 | 2014-10-21 19:27:01
Socket (748) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:27:02
Socket (748) | Shutdown and closed. | 2014-10-21 19:27:02
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:27:02
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:27:02
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:27:02
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:27:02
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:27:04
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59784 | 2014-10-21 19:27:06
Socket (800) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:27:07
Socket (800) | Shutdown and closed. | 2014-10-21 19:27:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:27:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:27:07
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:27:07
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:27:07
Current selected Data/Trading service: Rithmic Trading | 2014-10-21 19:27:09
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:27:09
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59784 | 2014-10-21 19:27:11
Socket (800) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-10-21 19:27:12
Socket (800) | Shutdown and closed. | 2014-10-21 19:27:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:27:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:27:12
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:27:12
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:27:12
Rithmic Trading | Port for executable: 59800 | 2014-10-21 19:27:14
Listening socket (1756), port 59800 | Closed. | 2014-10-21 19:27:14
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-10-21 19:27:14
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59800 | 2014-10-21 19:27:16
Socket (1756) | Connected. | 2014-10-21 19:27:16
Rithmic Trading | Connected to server. | 2014-10-21 19:27:16
Rithmic Trading | Sending logon request message. | 2014-10-21 19:27:16
Rithmic Trading | Starting the connection process to data and trading service. | 2014-10-21 19:27:16
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-10-21 19:27:16
Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-10-21 19:27:16
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-10-21 19:27:20
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-10-21 19:27:20
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-10-21 19:27:20
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-10-21 19:27:20
Rithmic Trading | Logon error from server | 2014-10-21 19:27:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-21 19:27:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-21 19:27:20
Socket (1756) | Shutdown and closed. | 2014-10-21 19:27:20
Rithmic Trading | Disconnected from the server. | 2014-10-21 19:27:20
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-10-21 19:27:20
Rithmic Trading | Bridge process is still running. | 2014-10-21 19:27:22
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59800 | 2014-10-21 19:27:24
[2014-10-21 15:46:26]
Sierra Chart - Max - Posts: 5732
You are getting a "permission denied" error, to resolve it refer to the documentation here:
https://www.sierrachart.com/index.php?page=doc/OptimusRithmic.php#ResolvingPermissionDenied
Sierra Chart Support
