Date/Time: Thu, 28 Nov 2024 00:29:57 +0000
ZB Symbol - Data not Downloading.
View Count: 933
[2014-10-21 11:00:35] |
Viacheslav Malafeev - Posts: 88 |
ZB.20141200.CME_F data not downloading. Nothing is in Message Log. What could be the problem? Other symbols like ZN and ZF are fine. Edit - Delete all data and Download won't help.
[2014-10-22 00:33:33] |
Provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-22 22:34:21] |
For some reason, it started to work automatically the next trading day as I turned my pc on. Thanks.
