Date/Time: Thu, 28 Nov 2024 00:36:25 +0000
Daily stock charts for SC historical
View Count: 1346
[2014-10-21 00:34:50] |
cmb999 - Posts: 211 |
Hello, it seems that around closing and opening times, double bar appears as latest bar for stocks (only). Not sure the pattern. here is an example. It happens every day, but not during RTH. the duplicate bar is timestamped for the next day. http://www.sierrachart.com/image.php?l=1413851165163.png |
[2014-10-21 04:48:13] |
This is inherently a hard problem to solve but we will consider it.
[2014-10-23 10:49:37] |
The issue is also present with FXCM daily charts. I use 5 pm (new york) close. double bar appears immediately, but reflecting latest closing price throughout the session. The bar usually (but not always) resets itself after the start of the following session . .
[2014-10-23 15:20:26] |
The problem with the FXCM Daily charts could be because of the FXCM data feed. Sometimes there is a problem with the high and low data from them.
