Date/Time: Thu, 28 Nov 2024 00:32:05 +0000
Line in chart
View Count: 955
[2014-10-20 23:29:34] |
bwasi - Posts: 34 |
I cant put "line" analysis into volume (2nd column) like before , I have to draw it manually ...Pls advice http://www.sierrachart.com/image.php?l=1413847427942.png |
[2014-10-23 02:50:28] |
bwasi - Posts: 34 |
any advice pls?
[2014-10-23 16:25:37] |
vegasfoster - Posts: 444 |
I'm on 1205 and it is working fine for me. What version are you on? Have you tried restarting? Sometimes after installing new versions I have to restart otherwise things are hinky.
[2014-10-28 12:43:48] |
bwasi - Posts: 34 |
Vegas, my version was 1202 then upgraded to 1205 after reading your comment. It was not the version I solved the problm by changing the sCALe setting of volume from default auto zero to automatic. It should be default automatic, I supposed . Also I change the sCAle setting of LINE to also to automatic. Thank you vegasfoster and have a nice day ! Date Time Of Last Edit: 2014-10-28 12:45:47
[2014-10-29 03:47:23] |
Here is the documentation for this and we will make sure that it explains to use an Automatic scale: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#AddingHorizontalLine Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-29 03:47:33
