Date/Time: Sun, 19 Jan 2025 06:22:32 +0000
Color Cell Numbers Bars Calculated Values
View Count: 2128
[2014-10-20 03:04:47] |
2garin - Posts: 184 |
Good afternoon. Please tell me: Is it possible to fill the color of the cell Numbers Bars Calculated Values of the indicator in accordance with their values? |
[2014-10-22 04:52:01] |
This can be done sort of. You cannot change the background color of the cells but you can change the foreground color of the text. Refer to step 6 here: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#NumericInformationBelowBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-23 00:21:42] |
Good day. I asked: Is it possible to paint the cell completely but not the text in the cell. |
[2014-10-23 02:01:56] |
No.
[2014-10-23 02:35:40] |
ganz - Posts: 1048 |
User62522 FYI: "Colored Bar Statistics" study |
[2018-02-28 07:29:55] |
whats1thingnow - Posts: 407 |
is it possible to do this now since the 2014 request? i want to replicate this market delta chart attached with "numbers bar calculated values" study |
[2018-02-28 18:28:24] |
We will look into this. So you want to color the background of the cell rather than the text foreground?
[2018-02-28 20:17:53] |
binaryduke - Posts: 375 |
Would be a great enhancement
[2018-03-01 02:57:48] |
yes thank you! basically the background of the calculated values will tell a story. shown is a 5 min bar footprint chart and numbers bar: 1st row = volume - light blue means little volume - mid blue means some volume - purple means higher than avg volume - dark blue means lots of volume 2nd row = delta of bar - light blue means delta is positive low in magnitude - mid blue means delta is mid positive - purple means delta is higher than avg - dark blue means delta is very positive (vice versa for negative delta) - pink - salmon - bright orange - dark red 3rd row = delta of day (same as row 2) -- for the comparison of values, it would be great if we compare it to 1) actual value - -1000 to 0, color 1 - 0-1000, color 2 - 1000-2000, color 3 - etc or 2) % relative to yesterday/today e.g. avg vol of today = x - 25% of avg, color 1 - 75% of avg, color 2 - 150% of avg, color 3 - 300% or more of avg, color 4 |
[2018-03-01 08:35:42] |
Acro - Posts: 441 |
I agree. Whilst I only have three rows of NBCV (delta, CD and volume) being able to use some "color intelligence" on the background colors would be very useful |
[2018-03-10 13:40:34] |
scalperdude - Posts: 20 |
Yes, would be a great enhancement. Cheers.
[2018-03-11 04:01:19] |
Logan W - Posts: 28 |
+1
[2018-03-18 00:25:54] |
3) % relative to yesterday/today vol + have an absolute minimum threshold e.g. avg vol of today = x - default color is white - 25% of avg, color 1 (light blue) - 75% of avg, color 2 (mid blue) - 150% of avg, color 3 (purple) - 300% or more of avg AND 'min threshold 50000', color 4 (dark blue) just adding more context here as i'm watching more how market delta does it (their color boxes changes over time) this is the way they have it implemented i think, because volume changes so much from a day to day basis even for the same market if we can set it like this, that means the color boxes CAN keep changing as new bars form e.g. 5 min after market started - bar1 (current bar) volume is at 10000 and it's the highest of the day - without the 'min threshold 50000', it would be color 4 (dark blue) - however, because there is a min threshold of 50000, even though it's the highest volume of the day, it will only be purple 10 min after market started - bar2 (current bar) volume is 60000 - this is now highest of the day & passes 'min threshold 50000', it would be color 4 (dark blue) - bar 1 color was purple, now will become light blue - math: ((10000+60000)/2=35000 = avg volume; .25*35000=8750; bar 1 is 10000, 10000 is greater than 8750) be great if anyone else can chime in if they know how market delta configures their number boxes |
[2018-03-23 20:47:09] |
John - SC Support - Posts: 37327 |
This is now available in version 1723 (currently the Prerelease). The documentation for how the background coloring is done can be found here: Numbers Bars: Calculated Values Background Coloring Logic For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
