Date/Time: Wed, 27 Nov 2024 22:50:23 +0000
sc.DownloadingHistoricalData
View Count: 935
[2014-10-20 01:44:45] |
Hendrixon - Posts: 130 |
Will it be 1 just when downloading new historical data from backfill? Or will it be 1 also when the chart is first loaded and populated by data from the scid file? |
[2014-10-21 04:41:14] |
Refer to the updated documentation for this ACSIL member.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-21 04:41:45
