Date/Time: Wed, 27 Nov 2024 22:28:40 +0000
Upgrade
View Count: 942
[2014-10-19 23:47:28]
guyl - Posts: 58
I received a message that we needed to upgrade with New Version under Help. I went to do that but I have 2 choices and I don't know which one to use so I don't mess up my existing charts. The first choice is Current version with OLD spreadsheets and the other is Current version with NEW spreadsheets.
Which do I use?
[2014-10-20 01:13:10]
If you are not using Spreadsheets, then choose New Spreadsheets.
[2014-10-20 01:22:29]
guyl - Posts: 58
To be clear I have many, many charts I have created with numerous indicators on them. Are you referring to those as spreadsheets?
[2014-10-20 01:44:23]
No. If you are not sure if you are using Spreadsheets, then almost certainly you are not.
To be on the safe side, you can update with "Old Spreadsheets". That probably is best.
