Date/Time: Wed, 27 Nov 2024 22:38:10 +0000
Rithmic Server Side OCO Question
View Count: 1181
[2014-10-19 17:59:36] |
User55519 - Posts: 37 |
Hello, I am confused if this is possible or not. On this page it says that server side OCO is not supported: http://www.sierrachart.com/index.php?page=doc/Rithmic.php This thread (which is older) says it IS supported: Server-side OCO and Bracket Orders Maybe I'm doing something stupid here, but I don't get it. Are server side OCO's supported with Rithmic and Optimus? What about bracket orders? Thanks! |
[2014-10-19 20:30:16] |
Server-side OCO is supported on newer versions of Sierra Chart when using Rithmic and Optimus. Server-side bracket orders are not supported.
