Date/Time: Wed, 27 Nov 2024 22:48:33 +0000
[User Discussion] - change in slope
View Count: 1185
[2014-10-19 14:28:12]
User28317 - Posts: 149
After several thrusts down I have been trying to identify the second leg up. The chart on the attached shows the change in color of the slope for the "Hull" moving average from the first wave to the second. My signals are giving me many false emails regarding the event. If you look at the attached chart the change in color is only after a higher low to clearly identify the second leg after a pullback. You can see that my chart is showing the blue bars as being the buy so I am missing something very important. I want the signal to only look at bar 35 and filter out the other signals.
Any ideas?
imagechange in slope.JPG / V - Attached On 2014-10-19 14:27:48 UTC - Size: 144.87 KB - 436 views
[2014-10-20 12:05:59]
=OR(AND(ID14.SG1>ID14.SG1[-1],ID14.SG1[-1]>ID14.SG1[-2],ID14.SG1[-2]>ID14.SG1[-3],ID14.SG1[-3]>ID14.SG1[-4],ID14.SG1[-4]>ID14.SG1[-5]),AND(ID13.SG1[-1]>ID14.SG1[-1],ID14.SG1>ID13.SG1,ID14.SG1>ID14.SG1[-1],ID13.SG1>ID13.SG1[-1]))
id13=25 hull
id14=16 hull
id15=20 ema
