Date/Time: Wed, 27 Nov 2024 22:50:15 +0000
Range Bars: Bar Period - EURUSD - why do I need to set it to 10 to make a 5 pip range bar?
View Count: 913
[2014-10-19 12:55:18]
ycomp - Posts: 321
When using Range Bars, why to get at 5 pip range bar must I specify 10 in the Bar Period of the Chart Settings Dialog?
I have not tested this extensively but it appears that other symbols behave more logically... like 10 would be a 10 Range Bar.
I'm using the demo standard feed
[2014-10-19 20:44:18]
This depends upon the Tick Size of the symbol.
For EURUSD this is .00005.
